[Qgis-developer] New SEXTANTE modeler interface
jr.morreale at enoreth.net
Tue May 7 05:07:11 PDT 2013
Le 2013-05-07 11:50, Victor Olaya a écrit :
> You mean the list of algorithms classified by providers (SAGA, GRASS,
> etc)?? The modeler uses the same configuration as the toolbox, so you
> should change it in the toolbox. Maybe I shoud add that in the
> modeler
> as well, so it can be changed from there...
Sorry, yes it's what I meant. I did not saw the list at the bottom of
the toolbox, I thought this option was somewhere in the SEXTANTE
configuration :)
> I agree that the interface now might be less clear in some cases...
> Do
> you think that it would be interesting to have an option to use the
> older modeler?
No, the smaller boxes are great ! my personal suggestions would be :
- to focus on one linear way of reading the screen (top to bottom, left
to right)
- put in/out on opposite side of the box
- use of zigzag/besier lines instead of straight ones
> 2013/5/7 <jr.morreale at enoreth.net>:
>> Hi Victor,
>> I'm testing 1.1, could you tell me how to switch back the modeler to
>> the
>> advanced GUI in the modeler ? I've not found a parameter to do so in
>> the
>> settings.
>> I appreciate that the boxes are now smaller and are directly showing
>> the
>> edit/del tools but I found the arrows to be confusing, they're now
>> passing
>> behind the boxes and often have to be read from left to right.
>> Regards,
>> Jean-Roc
>> Le 2013-04-24 07:55, Victor Olaya a écrit :
>>> Hey guys,
>>> I have made some changes to the interface of the modeler, taking
>>> into
>>> account a couple of suggestions from Tim and Andreas (thanks!). Not
>>> a
>>> big change, but I guess it's a nice usability improvement.
>>> Before starting rewriting the corresponding part in the manual and
>>> making new screenshots, I would appreciate if those of you that use
>>> SEXTANTE could have a quick look and give me your opinion.
>>> Thanks in advance!
>>> Víctor
