[Qgis-developer] New SEXTANTE modeler interface
Victor Olaya volayaf at gmail.com
Sun May 12 10:59:13 PDT 2013
Jean Roc
Sorry for the late reply. The idea of having inputs on one side and
outputs on the other one is good. I will wok on changing that, since
it looks like a good usability improvement.
The window is already not supposed to be modal, so I will also have a
look at that
thanks for your help!
2013/5/7  <jr.morreale at enoreth.net>:
> Hi Victor,
> I'm testing 1.1, could you tell me how to switch the modeler to the advanced
> GUI in the modeler ?
> The smaller boxes are good, showing directly the edit/del functions is also
> a good thing but now I found the arrows to more difficul to read as they
> often pass behind the boxes and go left to right.
> Would it be possible to avoid the modeler's windows getting a unswitchable
> focus ? Sometime I would like to get back to the main to check a simple
> thing like the name of a column without closing the modeler, open it back
> and reload the model.
> Regards,
> Jean-Roc
> Le 2013-04-24 07:55, Victor Olaya a écrit :
>> Hey guys,
>> I have made some changes to the interface of the modeler, taking into
>> account a couple of suggestions from Tim and Andreas (thanks!). Not a
>> big change, but I guess it's a nice usability improvement.
>> Before starting rewriting the corresponding part in the manual and
>> making new screenshots, I would appreciate if those of you that use
>> SEXTANTE could have a quick look and give me your opinion.
>> Thanks in advance!
>> Víctor
> Qgis-developer mailing list
