[Qgis-developer] Adding labels
Benoît Laurent
blaurent at heurisis.eu
Mon May 13 08:07:18 PDT 2013
Hello,
I am not sure to be on the right place to ask my question. If not, I beg
your pardon.
I am trying the write a Python script that :
- load a set of shapefile ;
- automatically add labels based on a field ;
- set the color, the size, etc. of my points.
For the moment, I can load the shapefiles. I also succeded in labeling
but I am not able to move the labels manually once created. Here is my
piece of code for labeling :
def add_label(self, layer):
layer.enableLabels(1)
myLabel = layer.label()
myLabel.setLabelField( QgsLabel.Text, 17)
myLabel.layerAttributes().setAlignment(4)
Is there an other way of doing this ? Is there samples of code ?
Thank you in advance.
Benoît
