[Qgis-developer] changing srs.db with coordinate system updater Plugin
Otto Dassau
dassau at gbd-consult.de
Tue May 14 13:07:55 PDT 2013
together with Diethard Jansen we found that the plugin we wrote seems to
work. But if we use the plugin and the crs is updated in srs.db the new
parameters are not used. But the parameters are used, if I create a user
defined crs.
Maybe I am missing something? Does QGIS save/use crs information somewhere
else?
Any help/information about this is welcome.
Regards
Otto
Am Mon, 13 May 2013 10:43:14 +0200
schrieb Otto Dassau <dassau at gbd-consult.de>:
> Hi,
> for QGIS 1.8 I tried to update the srs.db file
> in /usr/share/qgis/ressources/ with the coordinate system updater Plugin. I
> see the changed crs in tbl_srs and the former original crs is stored in
> srids4restore - so the plugin seems to work.
> The problem is, that the projection according to the new parameters does
> not work, although I can see the parameters in QGIS. QGIS still seems to
> use the former parameters.
> If I define a user defined projection in QGIS with the new parameters, the
> layer is projected with the new parameters.
> Does anybody has a solution for this?
> Thanks
> Otto
