[Qgis-developer] changing srs.db with coordinate system updater Plugin
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Tue May 14 22:51:23 PDT 2013
Hi Otto
As far as I understand if you change an existing crs in the srs.db you have to change it also in the /usr/share/proj/epsg (.\share\proj\epsg) file. And I had to delete the existing crs definition in /usr/share/gdal/pcs.csv. Probably you can change the definition here too (instead of deleting) but since it does not contain the parameters itself but only the ids of the values I just deleted them.
Regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-
> bounces at lists.osgeo.org] Im Auftrag von Otto Dassau
> Gesendet: Dienstag, 14. Mai 2013 22:08
> An: qgis-developer at lists.osgeo.org
> Betreff: Re: [Qgis-developer] changing srs.db with coordinate system updater Plugin
> Hi,
> together with Diethard Jansen we found that the plugin we wrote seems to work. But if
> we use the plugin and the crs is updated in srs.db the new parameters are not used.
> But the parameters are used, if I create a user defined crs.
> Maybe I am missing something? Does QGIS save/use crs information somewhere else?
> Any help/information about this is welcome.
> Regards
> Otto
> Am Mon, 13 May 2013 10:43:14 +0200
> schrieb Otto Dassau <dassau at gbd-consult.de>:
> > Hi,
> > for QGIS 1.8 I tried to update the srs.db file in
> > /usr/share/qgis/ressources/ with the coordinate system updater Plugin.
> > I see the changed crs in tbl_srs and the former original crs is stored
> > in srids4restore - so the plugin seems to work.
> > The problem is, that the projection according to the new parameters
> > does not work, although I can see the parameters in QGIS. QGIS still
> > seems to use the former parameters.
> > If I define a user defined projection in QGIS with the new parameters,
> > the layer is projected with the new parameters.
> > Does anybody has a solution for this?
> > Thanks
> > Otto
> Qgis-developer mailing list
