[Qgis-developer] Context help - locale (Consider country?)
Matthias Kuhn matthias.kuhn at gmx.ch
Wed May 15 03:37:31 PDT 2013
Hi Jürgen
On Mon 13 Mai 2013 20:08:36 CEST, Jürgen E. Fischer wrote:
> Hi Matthias,
> On Mon, 13. May 2013 at 17:14:31 +0200, Matthias Kuhn wrote:
>> I see the following possibilities:
>>  * keep the lang_COUNTRY suffix for these files and in case the specific
>> country does not exist, just take a random file with the same lang (e.g.
>> -de_CH will then use -de_AT because of the same -lang part and listed
>> before -de_DE).
>>  * always provide a fallback file (e.g. -de_CH would then search for
>> -de_CH, and if not existent for -de which it will find, because the file
>> -de_DE has been copied or symlinked there.)
>>  * drop the COUNTRY suffix (only look for -de and if that does not exist
>> take -en)
> Another possibility:
> Do something like I did with the grass modules, ie. generate cpp-code from
> en-US version and let linguist pick those up.  And let the rest work as usual.
Definitely the best possibility, because it fits best to the rest of
the UI translation.
Can you give me a hint on where to find what you have done with the
grass modules?
> I've started to do that (ie. create a QHash for QgsExpression and something for
> the context_helps).   I'll also replace the help viewer with something in gui
> (we use webkit in qgis anyway).
+1 for an embedded webkit widget somewhere. Right now the help  is a
separate process and I see no reason for or benefit of this, but the
behavior that it does not close when exiting the application seems to
be a disadvantage. As well as the recent hack to the paths get it to
run properly from the build directory because it resides in lib/.
You said you have started. Is that code already pushed to master?
> That way we would also not have to worry that the context and function help
> gets translated at all (AFAIK it's currently in the normal process) and also
> see when something needs to be updated (that doesn't happen now either).
> JÃrgen
Matthias
