[Qgis-developer] composer export fails for maps with label shadows
John C. Tull
jctull at gmail.com
Wed May 15 10:29:08 PDT 2013
Hi Régis,
On May 7, 2013, at 12:40 AM, Régis Haubourg <regis.haubourg at eau-adour-garonne.fr> wrote:
> Hi, This morning I tried to export in pdf some multimaps composers.
> I encounter an error - not crashing qgis, but leaving composer blank - on
> maps using new dropshadows for labels. %Maybe it's related to blending or
> only shadows. I switched back to buffer, and it works OK, even A0.
> Anyone confirms?
I've been producing pdf output maps from Composer using labels with drop shadows during the past week. Can you share the specific blend settings or, better, create a simple example qgs file you can share?
Thanks,
John
