[Qgis-developer] Composer load time
Rudi von Staden
rudivs at gmail.com
Thu May 23 07:41:07 PDT 2013
On Thu, May 23, 2013 at 4:17 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi,
> This is definitely not normal.
> It takes less than a second with QGIS master (from last night) on my
> Windows machine - regardless if it is an empty composer or an existing one.
> This is on Windows from the OSGeo4W installer.
> Perhaps you have thousands of SVG files that need to be loaded and cached?
It's a fresh install of master, and with the 1.8 install I've just deleted
the .qgis folder to see if it's something to do with that. The result is
the same - with a blank project and without adding any layers it takes 4
minutes to load the composer. So I don't see how it could be caching SVG
files.
Could there be some libraries that composer needs which I don't have
installed? Composer seems to work fine though when it loads, so it's a
strange issue. There are no messages to stdout when I run it from the
command line, but are there some error logs I could check?
On Thu, 23 May 2013 15:51:46 +0200, Rudi von Staden wrote:
>> Hi all,
>> Every time I load the composer (Ubuntu 12.10) it takes about 4 minutes
>> to load (even starting from a blank project). Is this the general
>> pattern, or is it perhaps something strange with my system?
>> Thanks,
>> Rudi
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130523/ae64dd5f/attachment.html>
