[Qgis-developer] Layers rendering order swapped (behavior change)
Andreas Neumann
a.neumann at carto.net
Thu May 23 13:23:23 PDT 2013
Hi Strk,
is the layer ordering panel active and controlling the layer rendering
order or is the layer panel controling the layer rendering order?
Andreas
Am 23.05.2013 22:20, schrieb Sandro Santilli:
> I saved a simple project with 3 layers from 1.8.0.
> Opening it with current master (commit:83445af) renders those
> 3 layers upside down (layer on top in the layer manager is
> rendered at the bottom in the map canvas).
> Moving layers around confirms the behavior: you have to move
> point layers at the bottom in order for them to NOT be covered
> by lineal layers.
> Is this intentional ?
> --strk;
> Qgis-developer mailing list
