[Qgis-developer] QGIS Server - GetPrint request does not respect text boxes size and position if dynamic content passed
kimaidou
kimaidou at gmail.com
Tue May 28 02:53:11 PDT 2013
Hi
I just made a small test and commented the line
currentLabel->adjustSizeToText();
Then recompile QGIS master and tested it with a classical text box (not
html rendered) with a long text.
I personnaly prefer the behaviour when this method is not called : the text
box keep the size set by the user in QGIS. And the text wraps when it
reaches the right side of the Box. I even tried with "HTML rendered" on
(and my fake X Server running), and it worked well too.
At the contrary, when adjustSizeToText is used, the box is transformed in a
one line box, which goes to the right of the entire composition (out of it)
: text does not wrap.
So for me, simply removing the adjustSizeToText call would be enough. Or we
have to make sure this method does the job correctly, which may be a bit
hard to implement : we need to avoid to have collision with other
composition items, etc.
Regards
Michael
2013/5/28 René-Luc D'Hont <rldhont at gmail.com>
> Hi Marco
>> I guess yes. 'adjustSizeToText()' works for text, not html. Html support
>> for composer label was added recently to the composer label class. Please
>> adapt the relevant lines to work with html labels too.
> I'll adapt it
>> >Question for Marco, Why removed label, if the request doesn't define a
>> value ? Why not used the default value ?
>> The idea was that the web client has the possibility to remove an
>> advertised text label completely if it is not used. E.g. if a composition
>> defines a text item with id 'author', the web client can simply ignore it
>> if it does not want to have author's name printed. Note that the labels
>> without ids are not removed as they are considered to be fix, so not
>> subject to client text replacement (original meaning of label id was that
>> this text item is subject to text replacement by web client. Later, the id
>> has been generalized as an id for every item type).
>> Another possibility would be to remove the item only if the client gives
>> an empty text and use the default text otherwise. What do you think?
> I prefer to remove the label only if the user gives an empty text.
> Can I do it ?
> Regards,
> René-Luc
> On 27.05.2013 22:23, rldhont wrote:
>> Hi Marco and other devs,
>>> In src/mapserver/qgsconfigparser.**cpp:530 we can read :
>>> //replace label text
>>> foreach ( QgsComposerLabel *currentLabel, composerLabels )
>>> QString title = parameterMap.value( currentLabel->id().toUpper() );
>>> if ( title.isEmpty() )
>>> //remove exported labels not referenced in the request
>>> if ( !currentLabel->id().isEmpty() )
>>> c->removeItem( currentLabel );
>>> delete currentLabel;
>>> continue;
>>> currentLabel->setText( title );
>>> currentLabel->**adjustSizeToText();
>>> This code is used to draw composer label with value defined by the QGIS
>>> WMS Server Request GetPrint.
>>> The bug defined in the issues #7894 http://hub.qgis.org/issues/**7894<http://hub.qgis.org/issues/7894>is probably du to the method adjustSizeToText()
>>> Someone can confim it ?
>>> Regards,
>>> René-Luc D'Hont
>>> 3Liz
>>> ______________________________**_________________
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Dr. Marco Hugentobler
>> Sourcepole - Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>> marco.hugentobler at sourcepole.**ch <marco.hugentobler at sourcepole.ch>
>> http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130528/696c9def/attachment.html>
