[Qgis-developer] TauDEM problem
marlon.calispa
marloncalispa at yahoo.es
Tue May 28 12:09:39 PDT 2013
Hi, Im really new in this community and I think its great!!
I´m trying to use the TauDEM extension in the Sextante plugin in my QGIS
master version 1.9, but when I run the module "Pit remove" I got the
message: "Oooops! SEXTANTE could not open the following output layers: Pit
Removed Elevation Grid:
C:\Users\HIDROT~1\AppData\Local\Temp\sextante\taudempitremovea9b8c8b800f74ac8843709f1aab51c18.tif"
I checked the folder and its empty, and in the log file there is just the
following:
Algorithm Pit Remove started.
Converting Outputs.
Loading result layers.
I thought it was a data problem but i have tried with some DEM obtaining the
same result.
There is any incompatibility problem with this plugin (W7, 64 bits)?
Thanks for you very appreciated help in advance.
View this message in context: http://osgeo-org.1560.x6.nabble.com/TauDEM-problem-tp5056516.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
