[Qgis-developer] TauDEM problem
Victor Olaya volayaf at gmail.com
Tue May 28 12:15:03 PDT 2013
Did you install and configure TauDEM? Unlike SAGA or GRASS, it is not
automatically installed with QGIS for windows when you use the OSGeo4W
installer
2013/5/28 marlon.calispa <marloncalispa at yahoo.es>:
> Hi, Im really new in this community and I think its great!!
> I´m trying to use the TauDEM extension in the Sextante plugin in my QGIS
> master version 1.9, but when I run the module "Pit remove" I got the
> message: "Oooops! SEXTANTE could not open the following output layers: Pit
> Removed Elevation Grid:
> C:\Users\HIDROT~1\AppData\Local\Temp\sextante\taudempitremovea9b8c8b800f74ac8843709f1aab51c18.tif"
> I checked the folder and its empty, and in the log file there is just the
> following:
> Algorithm Pit Remove started.
> Converting Outputs.
> Loading result layers.
> I thought it was a data problem but i have tried with some DEM obtaining the
> same result.
> There is any incompatibility problem with this plugin (W7, 64 bits)?
> Thanks for you very appreciated help in advance.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/TauDEM-problem-tp5056516.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
