[Qgis-developer] TauDEM problem
Alexander Bruy
alexander.bruy at gmail.com
Tue May 28 23:31:12 PDT 2013
as Victor already said, you need to install and configure TauDEM by
yourself. Please note,
that currently TauDEM provider supports only version 5.0.6 of TauDEM.
If you have TauDEM installed, but plugin don't work, try to execute
same command directly
in console and look if it works.
2013/5/28 marlon.calispa <marloncalispa at yahoo.es>:
> Hi, Im really new in this community and I think its great!!
> I´m trying to use the TauDEM extension in the Sextante plugin in my QGIS
> master version 1.9, but when I run the module "Pit remove" I got the
> message: "Oooops! SEXTANTE could not open the following output layers: Pit
> Removed Elevation Grid:
> C:\Users\HIDROT~1\AppData\Local\Temp\sextante\taudempitremovea9b8c8b800f74ac8843709f1aab51c18.tif"
> I checked the folder and its empty, and in the log file there is just the
> following:
> Algorithm Pit Remove started.
> Converting Outputs.
> Loading result layers.
> I thought it was a data problem but i have tried with some DEM obtaining the
> same result.
> There is any incompatibility problem with this plugin (W7, 64 bits)?
> Thanks for you very appreciated help in advance.
Alexander Bruy
