[Qgis-developer] TauDEM problem
Werner Macho
werner.macho at gmail.com
Wed May 29 00:05:43 PDT 2013
Hi Alexander!
TauDEM is a nice thing to work with ..
Could there be somewhat like a "check" made that checks for the existence
in "usual" places and if TauDEM is not found pop up pa warning with "You
have to install TauDEM by yourself in order to get TauDEM running"?
That would be really nice .. because a lot of people think that every
plugin in QGIS has the whole functionality inside the plugin and does not
need external tools..
Anyway .. Thanks a lot for creating TauDEM plugin!
kind regards
Werner
On Wed, May 29, 2013 at 8:31 AM, Alexander Bruy <alexander.bruy at gmail.com>wrote:
> Hi,
> as Victor already said, you need to install and configure TauDEM by
> yourself. Please note,
> that currently TauDEM provider supports only version 5.0.6 of TauDEM.
> If you have TauDEM installed, but plugin don't work, try to execute
> same command directly
> in console and look if it works.
> 2013/5/28 marlon.calispa <marloncalispa at yahoo.es>:
> > Hi, Im really new in this community and I think its great!!
> > I´m trying to use the TauDEM extension in the Sextante plugin in my QGIS
> > master version 1.9, but when I run the module "Pit remove" I got the
> > message: "Oooops! SEXTANTE could not open the following output layers:
> Pit
> > Removed Elevation Grid:
> C:\Users\HIDROT~1\AppData\Local\Temp\sextante\taudempitremovea9b8c8b800f74ac8843709f1aab51c18.tif"
> > I checked the folder and its empty, and in the log file there is just the
> > following:
> > Algorithm Pit Remove started.
> > Converting Outputs.
> > Loading result layers.
> > I thought it was a data problem but i have tried with some DEM obtaining
> the
> > same result.
> > There is any incompatibility problem with this plugin (W7, 64 bits)?
> > Thanks for you very appreciated help in advance.
> Alexander Bruy
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130529/284bf7fe/attachment.html>
