[Qgis-developer] TauDEM problem
Victor Olaya volayaf at gmail.com
Wed May 29 00:22:34 PDT 2013
Werner
Other SEXTANTE providers have that check, not just checking usual
places, but in some cases even running a tiny sample algorithm and
check it returns a result.
I will add a similar one to the TauDEM provider
Thanks for the suggestion
Victor
2013/5/29 Werner Macho <werner.macho at gmail.com>:
> Hi Alexander!
> TauDEM is a nice thing to work with ..
> Could there be somewhat like a "check" made that checks for the existence in
> "usual" places and if TauDEM is not found pop up pa warning with "You have
> to install TauDEM by yourself in order to get TauDEM running"?
> That would be really nice .. because a lot of people think that every plugin
> in QGIS has the whole functionality inside the plugin and does not need
> external tools..
> Anyway .. Thanks a lot for creating TauDEM plugin!
> kind regards
> Werner
> On Wed, May 29, 2013 at 8:31 AM, Alexander Bruy <alexander.bruy at gmail.com>
> wrote:
>> Hi,
>> as Victor already said, you need to install and configure TauDEM by
>> yourself. Please note,
>> that currently TauDEM provider supports only version 5.0.6 of TauDEM.
>> If you have TauDEM installed, but plugin don't work, try to execute
>> same command directly
>> in console and look if it works.
>> 2013/5/28 marlon.calispa <marloncalispa at yahoo.es>:
>> > Hi, Im really new in this community and I think its great!!
>> > I´m trying to use the TauDEM extension in the Sextante plugin in my QGIS
>> > master version 1.9, but when I run the module "Pit remove" I got the
>> > message: "Oooops! SEXTANTE could not open the following output layers:
>> > Pit
>> > Removed Elevation Grid:
>> > C:\Users\HIDROT~1\AppData\Local\Temp\sextante\taudempitremovea9b8c8b800f74ac8843709f1aab51c18.tif"
>> > I checked the folder and its empty, and in the log file there is just
>> > the
>> > following:
>> > Algorithm Pit Remove started.
>> > Converting Outputs.
>> > Loading result layers.
>> > I thought it was a data problem but i have tried with some DEM obtaining
>> > the
>> > same result.
>> > There is any incompatibility problem with this plugin (W7, 64 bits)?
>> > Thanks for you very appreciated help in advance.
>> Alexander Bruy
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
