[Qgis-developer] SIP API Update
Matthias Kuhn
matthias.kuhn at gmx.ch
Wed May 29 23:58:16 PDT 2013
Thank you Nathan, Great to see somebody tackle this task.
I sent a preliminary patch for gdaltools to the list a couple of days
ago.
I don't know if it helps and it sure is buggy, but whoever is going to
upgrade this plugin could have a look.
It's attached again here for convenience.
Matthias
On Don 30 Mai 2013 08:12:15 CEST, Nathan Woodrow wrote:
> Hey all,
> I have decided to manage the SIP API update process so that we can
> have it done by 2.0. This is an important update as leaving it for
> later will break every plugin yet again at later date which just
> leaves a really bad taste for people to deal with. A few plugin
> authors have already expressed that they would not be impressed having
> to do another major update again in the future. And I agree.
> So having said that this is the current plan:
> - I have created a branch with the SIP API v2 update
> - Update all the core plugins in the sipapi-udate[0] branch over the
> next couple of days
> - Merge into master
> I couldn't update all the core plugins myself BUT it would be a lot
> easier if I could call on the plugin authors to run though their own
> code and do the quick update. The risk of me doing it is that I might
> break something and not know it. You know your code best so the help
> would be greatly appreciated.
> I updated most of the console code and Salvatore has already cleaned
> the rest up for me so that is one thing out of the way.
> And here comes the kicker: I would like to do this as quickly as we
> can so to reduce the gap between master and the branch. The sooner we
> merge it to master the sooner we can open it to wider testing, but I
> don't expect to run into any major issues when we do.
> If you are not aware of what benefits the SIP API update will bring
> here is a quick example:
> Before:
> >>> str(yourlineedit.text().toString())
> 'Hello World'
> >>> feature["column"].toInt()[0]
> 100
> After
> >>> yourlineedit.text()
> 'Hello World'
> >>> feature["column"]
> 1000
> It will make life for us and plugin authors a hell of a lot easier.
> I have put together a quick guide[1] with some examples. It is open
> edit so feel free to add any notes you have. It might be good to turn
> it into a plugin translate guide for future plugin authors moving to 2.0.
> Regards,
> Nathan
> [0] https://github.com/qgis/Quantum-GIS/tree/sipapi-update
> [1] https://docs.google.com/document/d/1S85DMEC71AOzTkF1_EpnF0dhVb2On2EVq4E5s1EXoNM/edit?usp=sharing
> Qgis-developer mailing list
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130530/6a88a20d/attachment.bin>
