[Qgis-developer] QGIS 2.0 point release?
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Nov 1 03:49:33 PDT 2013
> It's fine for us that control the hardware we run stuff on but a lot of
> people don't and have to go though a major process to get an update.
To that end, would it be possible to create an update that's more like a
patch of the sort that Windows, ArcGIS, most-games use, rather than (or
maybe on top of) an entirely new install? I realise this would be a lot of
work to initially set up (I don't think QGIS has this ability yet?), but
for end users, it would make keeping up to date much easier.
Joanthan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131101/3a29d30f/attachment.html>
