[Qgis-developer] QGIS 2.0 point release?
Nathan Woodrow
madmanwoo at gmail.com
Fri Nov 1 03:51:27 PDT 2013
I have experimented with a couple of binary patch making tools, never could
get any of them to really work but that is a good idea if someone has the
skills.
- Nathan
On Fri, Nov 1, 2013 at 8:49 PM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> It's fine for us that control the hardware we run stuff on but a lot of
>> people don't and have to go though a major process to get an update.
> To that end, would it be possible to create an update that's more like a
> patch of the sort that Windows, ArcGIS, most-games use, rather than (or
> maybe on top of) an entirely new install? I realise this would be a lot of
> work to initially set up (I don't think QGIS has this ability yet?), but
> for end users, it would make keeping up to date much easier.
> Joanthan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131101/5de3d4b7/attachment.html>
