[Qgis-developer] Does spatial index improve performance using the class QgsGeometry.intersects()?
Stefano Masera stefano.masera at arpa.piemonte.it
Wed Nov 6 00:07:51 PST 2013
Thank you very much.
It's a good explanation.
Only another think.
Which is the difference to create a spatial index in this way:
feat_all = layer.dataProvider().getFeatures()
layer_spIndex = QgsSpatialIndex()
for feat in feat_all:
layer_spIndex .insertFeature(feat )
Or in this way:
layer.dataProvider().createSpatialIndex()
It seems to work only in the first case.
Thanks
Stefano
----- Messaggio originale -----
Da: "Daniel" <danielvaz at gmail.com>
A: "Stefano Masera" <stefano.masera at arpa.piemonte.it>
Cc: "qgis-developer" <qgis-developer at lists.osgeo.org>
Inviato: Lunedì, 4 novembre 2013 15:55:25
Oggetto: Re: [Qgis-developer] Does spatial index improve performance using the class QgsGeometry.intersects()?
Try it
http://nathanw.net/2013/01/04/using-a-qgis-spatial-index-to-speed-up-your-code/
Best regards.
On Mon, Nov 4, 2013 at 9:16 AM, Stefano Masera < stefano.masera at arpa.piemonte.it > wrote:
Hi list,
I don't know exactly how spatial index works, so I ask this question.
I have two layers and I want to check which features of the first layer intersect the features of the second one.
I write a simple script where I create the spatial index for both themes and I use the class QgsGeometry.intersects() to check the intersections.
I cannot understand why the executing time is the same even if I create or I don't create the spatial index for the layers.
Note:
- The first layer (polilyne) has 20000 features, the second (polygon) has 600 features.
- To test the script insert the path of a check file
- To compare time executing you have to comments the two lines (21 and 22) in which I create the spatial index and cancel the file *.qix on the hard disk.
Thanks
Stefano Masera
##input_layer1_polyline=vector
##input_layer2_polygon=vector
from qgis.core import *
from PyQt4.QtCore import *
from PyQt4.QtGui import *
import processing
import time
# start time
start_time = time.time()
# opens a check file: insert path
file = open("INSERT PATH","w")
# gets vector layer
layer1_polyline = processing.getobject(input_layer1_polyline)
layer2_polygon = processing.getobject(input_layer2_polygon)
# creates SpatialIndex
layer1_polyline.dataProvider().createSpatialIndex()
layer2_polygon.dataProvider().createSpatialIndex()
# gets features from layers
polyline_feat_all = layer1_polyline.dataProvider().getFeatures()
for polyline in polyline_feat_all:
# writes in a check file the polyline
file.write("polyline: " + str( polyline.id ()) + "\n")
polygon_feat_all = layer2_polygon.dataProvider().getFeatures()
for polygon in polygon_feat_all:
if polyline.geometry().intersects(polygon.geometry()) == 1:
# writes in a check file the intersect polygon
file.write("\t" + "intersect polygon: " + str( polygon.id ()) + "\n")
# end time
end_time = time.time()
file.write("\n" + "Execution time: " + str(end_time - start_time) + "\n")
file.close()
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
Daniel Vaz
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131106/bf5b95f9/attachment-0001.html>
