[Qgis-developer] Select datum transform in QGIS
Jürgen E. Fischer jef at norbit.de
Thu Nov 7 08:21:33 PST 2013
Hi Marco,
On Thu, 07. Nov 2013 at 16:39:35 +0100, Marco Hugentobler wrote:
> - The dialogs asking for datum transform could be annoying. Does it need
> an option to suppress it (and should it be enabled / disabled by
> default)?
Or the OTFR dialog could already produce a list of available transforms for
each CRS used in layers - maybe with the last used transform for each
combination preselected.
> - The synchronisation of srs.db with datum_shift.csv makes the install  time
> longer (maybe it can be solved more efficiently?)
Is that really significant?  I suppose using the same connection as syncDb()
would help (just because it does it's thing in a transaction).
> - To receive the current QgsCoordinateTransformation for a layer, tools
> may query QgsMapRenderer::tr (or QgsMapRenderer::mapToLayerCoordinates
> etc.). Creating a new QgsCoordinateTransform from layerCRS and mapCRS is
> not correct in all cases any more.
Who's bad idea was it to call that thing tr()? ;)   transformation() is
probably better for a public method.
> What are your opinions / suggestions?
Why is it in a separate branch?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)                                   IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
