[Qgis-developer] Select datum transform in QGIS
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Fri Nov 8 08:22:15 PST 2013
Hi Jürgen
>Is that really significant? I suppose using the same connection as syncDb()
>would help (just because it does it's thing in a transaction).
That was it, I moved everything into a transaction and it is super fast now.
>Who's bad idea was it to call that thing tr()? ;) transformation() is
>probably better for a public method.
He, he. At least it saved a few bytes on the development machines :-)
>Why is it in a separate branch?
Ok, I'll merge it into master. Hopefully it does not cause too much
damage...
Regards,
Marco
On 07.11.2013 17:21, Jürgen E. Fischer wrote:
> Hi Marco,
> On Thu, 07. Nov 2013 at 16:39:35 +0100, Marco Hugentobler wrote:
>> - The dialogs asking for datum transform could be annoying. Does it need
>> an option to suppress it (and should it be enabled / disabled by
>> default)?
> Or the OTFR dialog could already produce a list of available transforms for
> each CRS used in layers - maybe with the last used transform for each
> combination preselected.
>> - The synchronisation of srs.db with datum_shift.csv makes the install time
>> longer (maybe it can be solved more efficiently?)
>> - To receive the current QgsCoordinateTransformation for a layer, tools
>> may query QgsMapRenderer::tr (or QgsMapRenderer::mapToLayerCoordinates
>> etc.). Creating a new QgsCoordinateTransform from layerCRS and mapCRS is
>> not correct in all cases any more.
>> What are your opinions / suggestions?
> Jürgen
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
