[Qgis-developer] Data entry: various issues with widgets and drag&drop designer
Paolo Cavallini
cavallini at faunalia.it
Mon Nov 11 07:01:10 PST 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 11/11/2013 15:56, Andreas Neumann ha scritto:
> I think a checkbox is reasonably well suited for yes/no, true/false.
> What you describe is a radio-button - which would be a different
> widget in my opinion. It should not replace the checkbox but should be
> an additional widget.
IMHO a checkbox is a non-exclusive choice among a list, a radio button is an
alternative between two items. If this is true, the current behaviour of the widget
is one of a radio button.
> Have you tried the "Alias"? It should do exactly what you want and
> works for both the standard form and the d'n'drop form
Great, thanks: I was trying to use the comment, as Alias was hidden on a small screen.
Andreas, can you confirm the possible bug on the Value map widget?
Thanks a lot.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlKA8TYACgkQ/NedwLUzIr5aZwCeIo1OuRsqwVdJsOiUZ/4Alltx
vu0AoIT/CqFpMNEl17cyyA/vULpHwRy5
=BXcM
-----END PGP SIGNATURE-----
