[Qgis-developer] Composer crash after setting composition
Alexander Bruy
alexander.bruy at gmail.com
Tue Nov 12 02:37:40 PST 2013
Hi all,
playing with QGIS composer I found that it crashes after setting composition
via Python. If I just open new composer from plugin all fine, but if I
try to set
prepared composition (to allow user tweak it) I got crash. Interestingly, that
same code works fine from Python console, issue exists only if I run code
from plugin.
Ticket in redmine with test plugin and crash dump [0].
Anyone confirms? Any ideas what is wrong?
[0] https://hub.qgis.org/issues/8996
Thanks
Alexander Bruy
