[Qgis-developer] Composer crash after setting composition
Matthias Kuhn
matthias.kuhn at gmx.ch
Tue Nov 12 03:20:39 PST 2013
Maybe the composition gets garbage collected and you need to make sure,
you keep a reference to it, as long as its used?
Or is it supposed, that ownership is transferred?
Matthias
On Die 12 Nov 2013 11:37:40 CET, Alexander Bruy wrote:
> Hi all,
> playing with QGIS composer I found that it crashes after setting composition
> via Python. If I just open new composer from plugin all fine, but if I
> try to set
> prepared composition (to allow user tweak it) I got crash. Interestingly, that
> same code works fine from Python console, issue exists only if I run code
> from plugin.
> Ticket in redmine with test plugin and crash dump [0].
> Anyone confirms? Any ideas what is wrong?
> [0] https://hub.qgis.org/issues/8996
> Thanks
