[Qgis-developer] Print composer item resizing broken?
Andreas Neumann
a.neumann at carto.net
Tue Nov 12 03:10:04 PST 2013
Hi Nyall,
You were right - these were locked items. Depending on the zoom factor
the lock icon is hidden under the handles - that's probably why I did
not see the lock item.
I closed the bug report http://hub.qgis.org/issues/9044
The shortcut issue still exists. Maybe it is because I have installed
QGIS 2.0 and 2.1 in parallel? Do the settings of the two versions
interfer with each other?
Thanks,
Andreas
Am 2013-11-12 05:33, schrieb Nyall Dawson:
>> In the current master I cannot resize items interactively in the print
>> composer. It reacts to resizing, but after I release the mouse button
>> the width or height of the item jumps back to the original
>> width/height.
> Andreas,
> Can you try clicking the "Unlock all" button and then try again?
> That's the kind of behaviour which applies at the moment to locked
> items. It's not great, but it's waiting on me implementing
> http://hub.qgis.org/issues/4358 (it's underway at the moment, see [0]
> ). Then I'll make it so locked items can't be selected at all, and
> pass any mouse interactions to the next unlocked item below them.
> Let me know if unlocking the items helps with this.
>> On Windows I noticed that many shortcuts are not available: e.g.
>> delete
>> (del), paste in place (ctrl-shift-v), undo (ctrl-z), select all
>> (ctrl-a). Somehow they are not assigned anymore? On Ubuntu they are
>> still correctly assigned.
> I can't replicate this myself -- is anyone else seeing this behaviour?
> Nyall
> [0] https://github.com/nyalldawson/QGIS/tree/composer_model
