[Qgis-developer] Access to Run Feature Action tool from API
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Nov 12 23:11:06 PST 2013
Hi Thomas,
In the latest master, you can now use:
iface.actionFeatureAction.trigger()
Cheers,
Denis
On 11/11/2013 03:21 PM, Thomas Colley wrote:
> Thanks very much for that, looks good, I'll give it a go!
> Cheers
> Tom
> *From:*Denis Rouzaud [mailto:denis.rouzaud at gmail.com]
> *Sent:* 11 November 2013 13:59
> *To:* Thomas Colley; qgis-developer at lists.osgeo.org
> *Subject:* Re: [Qgis-developer] Access to Run Feature Action tool from API
> Ah, ok, sorry.
> Not sure you can actually set a predefined map tool using the API
> since mFeatureAction is defined in a private class Tools [0].
> I would ask confirmation for this.
> Otherwise, you could create your own map tool QgsMapToolFeatureAction
> with your defined action. You can use as example the code in [1] and
> [2], that would be:
> featureAction = new QgsMapToolFeatureAction( self.iface.mapCanvas() )
> featureAction->setAction( yourAction )
> self.iface.mapCanvas().setMapTool( featureAction )
> Hope it helps a bit.
> Cheers,
> Denis
> [0] https://github.com/qgis/QGIS/blob/master/src/app/qgisapp.h#L1337
> [1] https://github.com/qgis/QGIS/blob/master/src/app/qgisapp.cpp#L1981
> [2] https://github.com/qgis/QGIS/blob/master/src/app/qgisapp.cpp#L4196
> On 11/11/2013 02:27 PM, Thomas Colley wrote:
> Hi Denis
> Thanks for your reply.
> What I'm trying to do is set Run Feature Action to be the active
> tool (equivalent of user pressing the action button on the
> attributes toolbar) rather than actually programmatically firing
> the action itself.
> This command does exactly what I'm looking for but with the
> identify tool
> qgis.utils.iface.actionIdentify().trigger()
> Hope this makes sense
> Thanks again
> Tom
> *Sent:* 11 November 2013 12:37
> <mailto:qgis-developer at lists.osgeo.org>
> from API
> Hi Thomas,
> This should do the job:
> layer.actions().doAction( idx, feature )
> QgsAttributeAction is a registry, and you can run/add/remove
> action from it.
> http://qgis.org/api/classQgsAttributeAction.html
> Cheers,
> Denis
> On 11/11/2013 11:12 AM, Thomas Colley wrote:
> Hi Everyone
> Is there a way to access the Run Feature Action tool from the API?
> Most other tools can be switched with
> qgis.utils.iface.action...().trigger()
> but I can't see any reference to the action tool in there.
> In the API I can see actionFeatureAction under QgisApp and
> QgisAppInterface but I'm not sure how to or if they can be accessed from
> inside QGIS.
> Thanks
> Tom
> -----Original Message-----
> From:qgis-developer-bounces at lists.osgeo.org <mailto:qgis-developer-bounces at lists.osgeo.org>
> [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of
> qgis-developer-request at lists.osgeo.org <mailto:qgis-developer-request at lists.osgeo.org>
> Sent: 09 November 2013 20:00
> To:qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>
> Subject: Qgis-developer Digest, Vol 97, Issue 26
> Send Qgis-developer mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-developer-owner at lists.osgeo.org <mailto:qgis-developer-owner at lists.osgeo.org>
> When replying, please edit your Subject line so it is more specific than
> "Re: Contents of Qgis-developer digest..."
> Today's Topics:
> 1. Re: Roadmap for 2.2 (Nathan Woodrow)
> 2. Re: Roadmap for 2.2 (Marco Bernasocchi)
> 3. Re: Bug with avoid intersection - willing to fund fix
> (Sandro Santilli)
> 4. Re: Roadmap for 2.2 (Richard Duivenvoorde)
> 5. Re: Bug with avoid intersection - willing to fund fix
> (George Silva)
> 6. Plugin [233] Contour plugin approval notification.
> (noreply at qgis.org <mailto:noreply at qgis.org>)
> Message: 1
> Date: Sat, 9 Nov 2013 20:14:43 +1000
> From: Nathan Woodrow<madmanwoo at gmail.com> <mailto:madmanwoo at gmail.com>
> To:"qgis-developer at lists.osgeo.org" <mailto:qgis-developer at lists.osgeo.org> <qgis-developer at lists.osgeo.org> <mailto:qgis-developer at lists.osgeo.org>
> Subject: Re: [Qgis-developer] Roadmap for 2.2
> Message-ID:
> <CAAi8Yg9mz-BYJb1cHC1xTioeiD1_oXc81uSrZL42wqbnLtRYXA at mail.gmail.com> <mailto:CAAi8Yg9mz-BYJb1cHC1xTioeiD1_oXc81uSrZL42wqbnLtRYXA at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> +1 to feb/jun/oct for me.
> - Nathan
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131109/af <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131109/af637a85/attachment-0001.html>
> 637a85/attachment-0001.html> <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131109/af637a85/attachment-0001.html>
> Message: 2
> Date: Sat, 9 Nov 2013 11:32:31 +0100
> From: Marco Bernasocchi<marco at bernawebdesign.ch> <mailto:marco at bernawebdesign.ch>
> To: qgis-developer<qgis-developer at lists.osgeo.org> <mailto:qgis-developer at lists.osgeo.org>
> Message-ID:
> <CALWXeEFdEwaCr764pywm6vyCLB9nkRqcMeeVuf12G0iDpknUnQ at mail.gmail.com> <mailto:CALWXeEFdEwaCr764pywm6vyCLB9nkRqcMeeVuf12G0iDpknUnQ at mail.gmail.com>
> I d try to avoid august and December due to many people having holidays.
> jan/may/sep would coincide with the hack fest which might be sub
> optimal.
> +1 for feb/jun/oct or mar/jul/nov
> if we consider the hack fest in sept/april, then the feb schedule would
> have the hackfest in the feature freeze month while the march schedule
> not.
> opinions?
> ciao
> Marco Bernasocchi (mobile)
> http://opengis.ch
> On 9 Nov 2013 18:13, "J?rgen E."<jef at norbit.de> <mailto:jef at norbit.de> wrote:
> Hi,
> On Tue, 05. Nov 2013 at 13:37:12 +0100, Vincent Picavet wrote:
> Does jan/may/sep sound preferable? feb/jun/oct or mar/jul/nov or
> apr/aug/dec any better? Any preference on the week or weekday
> such a release should happen (eg. 3rd friday of the month)?
> Better not have a release in august because of summer holidays.
> feb/jun/oct would be my favorite.
> Anyone else?
> J?rgen
> J?rgen E. Fischer norBIT GmbH Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstra?e 13 Fax.
> +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM) IRC: jef on
> FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme
> mbH Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> URL:
> <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131109/56 <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131109/564bb605/attachment-0001.html>
> 4bb605/attachment-0001.html> <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131109/564bb605/attachment-0001.html>
> Message: 3
> Date: Sat, 9 Nov 2013 12:18:27 +0100
> From: Sandro Santilli<strk at keybit.net> <mailto:strk at keybit.net>
> To: George Silva<georger.silva at gmail.com> <mailto:georger.silva at gmail.com>
> Cc: qgis-developer<qgis-developer at lists.osgeo.org> <mailto:qgis-developer at lists.osgeo.org>, Giovanni Manghi
> <giovanni.manghi at faunalia.pt> <mailto:giovanni.manghi at faunalia.pt>
> Subject: Re: [Qgis-developer] Bug with avoid intersection - willing to
> fund fix
> Message-ID: <20131109111827.GA4496 at cdb>
> Content-Type: text/plain; charset=us-ascii
> On Thu, Nov 07, 2013 at 04:26:32PM -0200, George Silva wrote:
> QGis does the explicit noding of the first adjancent feature, but the
> results are inconsistent.
> Noding should involve all nearby features, updating each of them to
> include the new node.
> Sometimes it works, sometimes it doesnt. I've tried many things to see
> if I could find a reproducible series of steps, but without success.
> I bet, it's not easy to "manually" put points in critical spots of a
> floating point grid !
> --strk;
> Message: 4
> Date: Sat, 09 Nov 2013 13:05:57 +0100
> From: Richard Duivenvoorde<rdmailings at duif.net> <mailto:rdmailings at duif.net>
> Message-ID:<527E2525.9090000 at duif.net> <mailto:527E2525.9090000 at duif.net>
> Content-Type: text/plain; charset=ISO-8859-1
> apr/aug/dec any better? Any preference on the week or weekday such a
> Good plan! I do not care which three months, it will always coincide
> with something or a holiday somewhere in the world :-)
> Pick one, and let us try to stick to that.
> Regards,
> Richard
> Message: 5
> Date: Sat, 9 Nov 2013 10:32:22 -0200
> From: George Silva<georger.silva at gmail.com> <mailto:georger.silva at gmail.com>
> To: George Silva<georger.silva at gmail.com> <mailto:georger.silva at gmail.com>, kimaidou
> <kimaidou at gmail.com> <mailto:kimaidou at gmail.com>, Giovanni Manghi
> <giovanni.manghi at faunalia.pt> <mailto:giovanni.manghi at faunalia.pt>,
> fund fix
> Message-ID:
> <CAGyPVTuNG3MSAfTTGSMHVxmnH2NR2SfEr1MgefaJG00vqWUoDw at mail.gmail.com> <mailto:CAGyPVTuNG3MSAfTTGSMHVxmnH2NR2SfEr1MgefaJG00vqWUoDw at mail.gmail.com>
> Any comments from the QGis crowd?
> Thanks
> On Sat, Nov 9, 2013 at 9:18 AM, Sandro Santilli<strk at keybit.net> <mailto:strk at keybit.net> wrote:
> the results are inconsistent.
> see
> if I
> --strk;
> George R. C. Silva
> SIGMA Consultoria
> http://www.consultoriasigma.com.br/
> URL:
> <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131109/7e <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131109/7e64e09f/attachment-0001.html>
> 64e09f/attachment-0001.html> <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131109/7e64e09f/attachment-0001.html>
> Message: 6
> Date: Sat, 09 Nov 2013 17:53:58 -0000
> From:noreply at qgis.org <mailto:noreply at qgis.org>
> To:ccrook at linz.govt.nz <mailto:ccrook at linz.govt.nz>,ccrook at linz.govt.nz <mailto:ccrook at linz.govt.nz>,
> Subject: [Qgis-developer] Plugin [233] Contour plugin approval
> notification.
> Message-ID:<20131109175358.1426.36911 at qgis.osgeo.osuosl.org> <mailto:20131109175358.1426.36911 at qgis.osgeo.osuosl.org>
> Content-Type: text/plain; charset="utf-8"
> Plugin Contour plugin approval by ccrook.
> The plugin version "[233] Contour plugin 1.0.3" is now unapproved
> Link:http://plugins.qgis.org/plugins/contour/
> End of Qgis-developer Digest, Vol 97, Issue 26
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131113/b59d9f4e/attachment-0001.html>
