[Qgis-developer] Bug with avoid intersection - willing to	fund	fix
    Blumentrath, Stefan
    Stefan.Blumentrath at nina.no
    Thu Nov 14 01:40:25 PST 2013
Hi George
I had a lot of trouble with those issues too, and I would really love to see them fixed. In other words, I agree with Giovanni that these are pretty important bugs for many and not really uncommon digitization use-cases and would support his categorization as blocker...
However, my current workaround is to ignore the untidiness in the topology at first and then send the vector dataset through GRASS which is (at least for not too big datasets) quite convenient using the Sextante/Processing framework (see also discussion here):
http://osgeo-org.1560.x6.nabble.com/Running-v-clean-on-a-QGIS-vector-layer-Polygon-through-Sextante-td5050418.html
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131114/9b34857b/attachment.html>
