[Qgis-developer] Bug with avoid intersection - willing to fund fix
Andreas Neumann
a.neumann at carto.net
Thu Nov 14 01:53:34 PST 2013
So if there is so much interest in having this issue fixed I assume that
there would be plenty out there who would fund the fix!
The fix won't happen if noone pays for it - just complaining about this
does not help.
Get an estimate from some developer (e.g. Sandro Santilli oder
Sourcepole) to know how much it would cost to fix.
As much as I like GRASS - and it is very good to know that this
workaround exists (thanks Stefan for mentioning it!) - I don't think it
is reasonable to ask people to go through GRASS to get proper data out
of their QGIS digitized data set.
Who will take the lead to ask a developer?
Andreas
Am 14.11.2013 10:40, schrieb Blumentrath, Stefan:
> Hi George
> I had a lot of trouble with those issues too, and I would really love to see them fixed. In other words, I agree with Giovanni that these are pretty important bugs for many and not really uncommon digitization use-cases and would support his categorization as blocker...
> However, my current workaround is to ignore the untidiness in the topology at first and then send the vector dataset through GRASS which is (at least for not too big datasets) quite convenient using the Sextante/Processing framework (see also discussion here):
> http://osgeo-org.1560.x6.nabble.com/Running-v-clean-on-a-QGIS-vector-layer-Polygon-through-Sextante-td5050418.html
> Cheers
> Stefan
> Qgis-developer mailing list
