[Qgis-developer] [Ubuntu] Question on QGIS Build and SIP
    Randal Hale
    rjhale at northrivergeographic.com
    Sat Nov 23 08:42:58 PST 2013
Alex - thank you!
I saw where he was updating but I wanted to learn a bit more on how all
of this clicks together. I've got two sore spots - Mr SID and ESRI File
Based Geodatabases so I decided to do a custom build to see if I could
get it done and remotely do it in the right order. I learned quite a bit
on my first go around. I might try it again tonight for kicks.
Thanks again.
Randy
Randal Hale, GISP
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
<mailto:rjhale at northrivergeographic.com>
twitter:rjhale
http://about.me/rjhale
On 11/23/2013 11:38 AM, Alex Mandel wrote:
> On 11/23/2013 07:58 AM, Randal Hale wrote:
>> I'm not entirely sure where this should go - but I see this one as more
>> of a ubuntu question than a QGIS developer...or maybe it's both so I've
>> cross posted.
>> To learn a bit more - I've compiled (checkinstall)
>> gdal/ogr/geos/proj/grass/postgis (not in that order) and for the final
>> proof I'm insane - QGIS 2.0.1. I'm compiling on ubuntu 13.10 - there's
>> one error that keeps flaring up:
>> CMake Error at cmake/FindSIP.cmake:54 (MESSAGE):
>>    Could not find SIP
>> Call Stack (most recent call first):
>>    CMakeLists.txt:550 (FIND_PACKAGE)
>> I've installed the package I thought installed SIP - and apparently I
>> didn't....I think it's python-qt4-dev but I've went a bit crosseyed with
>> my note taking.
> You can always do:
> sudo apt-get build-dep qgis
> Which reads the qgis package for dependencies on an ubuntu/debian system
> and installs all the perquisites.
> Of course on 13.10 some of these might be older versions, so you can
> also add the qgis.org repo briefly to get the updated dependency list
> (probably the same).
> Then you can always look at the package control files:
> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable/+files/qgis_2.0.1-1%7Eraring1.debian.tar.gz
> Look at the file called control. It lists the packages needed.
> You're probably missing:
> python-sip
> python-sip-dev
> FYI, Jerome said he's updating Ubuntugis for Saucy this weekend.
> Thanks,
> Alex
