[Qgis-developer] Custom SRS in qGis2
Marica Landini
bulma at ferrara.linux.it
Mon Nov 25 13:00:02 PST 2013
dear developers,
we need to add our custom SRS in qGis2, in order to build the right call to
our WMS with the correct EPSG,
for example:
http://servizigis.regione.emilia-romagna.it/wms/ctr5?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=760705.00661945529282093,931095.61931572866160423,761403.97892956342548132,931660.17387389298528433&CRS=EPSG:202003&WIDTH=988&HEIGHT=798&LAYERS=Ctr5&STYLES=&FORMAT=image/png&DPI=98&MAP_RESOLUTION=98&FORMAT_OPTIONS=dpi:98
until the version 1.8 we added manually in qGis our EPSG:202003
specifications accessing directly to the apps/qgis/resources/srs.db:
-- EPSG:202003
insert into tbl_srs ( srs_id, description, projection_acronym,
ellipsoid_acronym, parameters, srid, auth_name, auth_id, is_geo,
deprecated)
values( 10271, 'Monte Mario / UTMRER - ESRI', 'tmerc', 'intl',
'+proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=500053.0 +y_0=-3999820.0
+ellps=intl +units=m +no_defs', 202003, 'EPSG', '202003', 0, 0);
we have done the same in qGis2 but still our EPSG:202003 it is not visible
in the list of available SRS in qGis2.
the question is?
- how the list of available SRS is created when qGis starts?
- is it possible to access to that list adding a “custom” EPSG
specifications ? (note that the qGis “Custom SR” functionality is not
enough for us, because then the call to WMS would be done with the value of
the parameter CRS=USER:100001 (for example) that it is not accepted by our
WMS server)
of course would be nice that the call to the WMS with a “Custom SR” with
the “name” (field “description” or fields “auth_name”+”:”+“auth_id”) of
the SR and not with the “USER:”+auth_id, as actually is. this would solve
our problem of adding manually our SR in the srs.db.
thanks in advance,
Marica
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Marica Landini
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131125/831349ba/attachment.html>
