[Qgis-developer] Projection of ESPG/ESRI
Alex Mandel
tech_dev at wildintellect.com
Wed Nov 27 11:12:24 PST 2013
On 11/27/2013 10:56 AM, Randal Hale wrote:
> So this question was going to be epic and confusing - and I just figured
> it out. I also Cross posted this to the developers list - so excuse the
> duplication.
> I have a user who sent me data in Georgia West State Plane NAD83 Feet.
> In QGIS this comes up as a custom projection so I decided to define it.
> According to QGIS I ended up with two EPSG choices - EPSG 102667 and
> EPSG 2240. So this lead to some back and forth on my part mostly because
> I was working tired. I searched the EPSG database and there is no
> 102667. This led to some head banging on my part.
> I searched http://spatialreference.org/ref/?search=Georgia+West+ and
> 102667 is defined as an ESRI projection. Except in QGIS it comes up as
> EPSG. Can this be fixed - can it be referenced as ESRI as opposed to EPSG?
I think that's a minor semantics issue, it's common knowledge that EPSG
code's over 10,000 are not actually official EPSG. But I'm not sure that
the label is stored in the db. Will have to look into that. More a
request to the developers list than here. And then of course I wonder if
we'll get in trouble for using the term ESRI without a trademark note.
Technically yes those projections come from the ESRI definitions, but
I'd guess that someone outside ESRI actually converted them to proj strings.
> Also - it seems when I pull data without a projection it inherits EPSG
> 4326 (WGS84) - is there a way in QGIS to pull in data with no
> projection? In some cases we have to figure it out - so it coming in as
> undefined is more helpful than inheriting an incorrect projection.
Just leave Projection on the fly off (the default). That will give you
the behavior of a naive coordinate system and a chance to figure out and
define the correct coordinate system.
> Anyway - Happy Thanksgiving for those of you who fall in that geographic
> social area.
> Randy
Thanks,
Alex
