[Qgis-developer] Shortcut changes in QGIS; call for opinions
A Huarte ahuarte47 at yahoo.es
Thu Nov 28 07:11:30 PST 2013
Hi, I would know objections in order to change some shortcut keys in QGIS desktop.
+ Delete selected features in map canvas -> DEL key without ask for confirmation.
   Now QGIS ask for confirmation first.
   Other GIS app desktops, Arcmap, gvSIG.... use DEL key.
+ Delete selected features in attribute table -> DEL key without ask for confirmation.
   Now QGIS uses Ctrl+D shortcut and ask for confirmation first.
+ Remove selected node of a feature -> 'backspace' key without ask for confirmation.
   Now QGIS uses DEL key, and similarly 'backspace' already deletes a node when drawing a feature.
+ Remove layer from legend -> Ctrl+D with ask for confirmation.
   Now QGIS does not ask for confirmation.
Our purpose is to standardize these keys and avoid unnecessary and continuous confirmation messages in an edit session (You can easily undo the removal using the UNDO option menu or Ctrl+Z shortcut).
You can see the current discussion in:
http://hub.qgis.org/issues/9094
Thank you very much!
Regards
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131128/c2ad7e3c/attachment.html>
