[Qgis-developer] [Qgis-user] Shortcut changes in QGIS; call for opinions
A Huarte
ahuarte47 at yahoo.es
Thu Nov 28 15:18:27 PST 2013
I agree with Nathan.
I think that 'D' should ask confirmation, we can imagine the reaction of a user removing accidentaly a configured layer.
'Ctrl+D' could remove layers without confirmation.
Alvaro
>________________________________
> De: Nathan Woodrow <madmanwoo at gmail.com>
>Para: Borys Jurgiel <lists at borysjurgiel.pl>
>CC: "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>; A Huarte <ahuarte47 at yahoo.es>; "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
>Enviado: Jueves 28 de noviembre de 2013 23:19
>Asunto: Re: [Qgis-user] [Qgis-developer] Shortcut changes in QGIS; call for opinions
>Given that adding/removing a complex layer can be expensive and there is no undo I would suggest to have a single key shortcut (D) with confirm and a modified one without (Ctrl-D). You want to avoid the user doing something dangerous and in this case that is removing a layer layer without undo.
>- Nathan
>On Fri, Nov 29, 2013 at 3:11 AM, Borys Jurgiel <lists at borysjurgiel.pl> wrote:
>Dnia czwartek, 28 listopada 2013 15:11:30 A Huarte pisze:
>>> + Remove layer from legend -> Ctrl+D with ask for confirmation.
>>> Now QGIS does not ask for confirmation.
>>What about leaving the possibibility to remove the layer without confirmation
>>with a separate shortcut?
>>Actually the first what I do after a fresh install is changing "Ctrl-D" to
>>simple "D", as I couldn't imagine myself using two fingers for such basic
>>action like layer removing ;)) The same with a dozen of other Ctrl-*
>>shortcuts. And I believe I'm not the only one.
>>Regards,
>>B.
>>_______________________________________________
>>Qgis-user mailing list
>>Qgis-user at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131128/971d39d3/attachment-0001.html>
