[Qgis-developer] [Qgis-user] Shortcut changes in QGIS; call for opinions
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Thu Nov 28 16:36:38 PST 2013
Instead of a confirmation when deleting a layer, an Undo-action for
already deleted layers would be much more helpful.
Cause you can happily confirm to delete sth, but figure out you were wrong
just a minute later ...
Cheers
Bernd
Am 29.11.2013, 00:18 Uhr, schrieb A Huarte <ahuarte47 at yahoo.es>:
> I agree with Nathan.
> I think that 'D' should ask confirmation, we can imagine the reaction of
> a user removing accidentaly a configured layer.
> 'Ctrl+D' could remove layers without confirmation.
> Alvaro
>> ________________________________
>> De: Nathan Woodrow <madmanwoo at gmail.com>
>> Para: Borys Jurgiel <lists at borysjurgiel.pl>
>> CC: "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>;
>> A Huarte <ahuarte47 at yahoo.es>; "qgis-user at lists.osgeo.org"
>> <qgis-user at lists.osgeo.org>
>> Enviado: Jueves 28 de noviembre de 2013 23:19
>> Asunto: Re: [Qgis-user] [Qgis-developer] Shortcut changes in QGIS; call
>> for opinions
>> Given that adding/removing a complex layer can be expensive and there
>> is no undo I would suggest to have a single key shortcut (D) with
>> confirm and a modified one without (Ctrl-D). You want to avoid the
>> user doing something dangerous and in this case that is removing a
>> layer layer without undo.
>> - Nathan
>> On Fri, Nov 29, 2013 at 3:11 AM, Borys Jurgiel <lists at borysjurgiel.pl>
>> wrote:
>> Dnia czwartek, 28 listopada 2013 15:11:30 A Huarte pisze:
>>>> + Remove layer from legend -> Ctrl+D with ask for confirmation.
>>>> Now QGIS does not ask for confirmation.
>>> What about leaving the possibibility to remove the layer without
>>> confirmation
>>> with a separate shortcut?
>>> Actually the first what I do after a fresh install is changing
>>> "Ctrl-D" to
>>> simple "D", as I couldn't imagine myself using two fingers for such
>>> basic
>>> action like layer removing ;)) The same with a dozen of other Ctrl-*
>>> shortcuts. And I believe I'm not the only one.
>>> Regards,
>>> B.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
