[Qgis-developer] Oracle connection dialog broken in 64 bit 2.0.1-2 ?
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Oct 3 04:35:33 PDT 2013
Hi Régis,
Windows x64 2.0.1-2 install here - the Oracle dialog works fine. I didn't
use the OSGEO installer but instead used the standalone one. Worth trying
that?
Cheers,
Jonathan
On 2 October 2013 08:47, Régis Haubourg <regis.haubourg at eau-adour-garonne.fr
> wrote:
> Hi,
> Oracle connection dialog does not show in 64 bits version (revision
> d94c044,
> gdal 1.10), installed with OSGEO4W here.
> I get a error message "Impossible to obtain Oracle selection dialog from
> provider".
> 32 bits versions does well (revision 341139bc, gdal 1.9.2).
> Something wrong only on my system? If someone can reproduce, I will open a
> ticket.
> Régis
> http://osgeo-org.1560.x6.nabble.com/Oracle-connection-dialog-broken-in-64-bit-2-0-1-2-tp5081363.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131003/2d23a53c/attachment.html>
