[Qgis-developer] QGIS 2 64bits, is it stable ?
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Oct 4 04:52:48 PDT 2013
> The stability of the current release is heavily influenced by
> increasing the major version number. What I mean with this is, that
> because for the next release only the minor number will increase, I
> expect it to be to be more stable and not less. Regardless of testing.
> Agreed, the new features should be expected to have bugs in, but with a
proper testing regime the regressions should be fewer as they'd get picked
up and the commit wouldn't/shouldn't be accepted until they're fixed.
You're right it won't cure everything, but it would mitigate a good chunk
of one subset of bug type.
Let me quote Martin Grässlin "I rather use a working system without unit
> tests than a system with unit tests that doesn’t work"
It sounds good, but it's a false dichotomy - why can't you have both?
Regards,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131004/6c3e97ac/attachment-0001.html>
