[Qgis-developer] QGIS 2 64bits, is it stable ?
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Oct 4 05:10:42 PDT 2013
> > It sounds good, but it's a false dichotomy - why can't you have both?
> because of limited resources. if all the 1.000.000+ users of QGIS would
> invest 1 euro
> per year in it, this would be quite feasible.
> All the best.
True, but that's back to my comment previously about what other projects do
- there's bound to be OS software out there that also has very limited
resources (most aren't supported by RedHat or IBM) yet manage a more
rigorous testing regime. What could be learnt from them? Staying within the
very-niche GIS world I know the GeoServer devs also complain about limited
resources (it appears to have far fewer committers than QGIS), yet they
have a unit-test requirement for all patches/commits and regular bugfix
releases. I know it's not like-for-like, but it's indicative of what might
be accomplished.
Kind regards,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131004/3caea8f9/attachment.html>
