[Qgis-developer] test new android package
Roel Vanhout roel.vanhout at gmail.com
Fri Oct 11 01:42:05 PDT 2013
Tried on a Nexus 10 tablet, install worked OK. Only 'issue' is cosmetic;
after the message that I need to install the 'necessitas' runtime, I'm
redirected to the play store. When I return from that, I get the message
(in qgis) 'necessitas not found' and I need to restart to resume the in-app
installation procedure to continue.
Apart from that, is this meant to be more than a proof of concept /
pre-alpha? Does it make sense for me to report bugs yet?
cheers,
roel
On Thu, Oct 10, 2013 at 6:55 PM, Marco Bernasocchi
<marco at bernawebdesign.ch>wrote:
> Hi all, I've been working on creating an android packae that is smaller
> than 50mb to fit the playstore.
> the pakage now includes only a small subset of the needed libs, all other
> libs are downloaded on the first run by ministro.
> all in all you will be downloding about 30mb for the apk plus 200mb
> dependencies plus 40mb qt, so do it on a wifi, i know it got bigger (used
> to be 150mb apk), but the adventage is that now qgis is small enough for
> the market (thus update notification will be available) and for each update
> you will have to rownload only what actually changed.
> To achieve this, I created a reporitory at http://android.qgis.org/**
> repository/ <http://android.qgis.org/repository/> that can actually be
> used by any android qt app that needs any of the available libs.
> so please, help me test this package and just report if the installation
> worked and you could start QGIS.
> thanks a lot Marco
> https://db.tt/sBa0e2Pu
> Marco Bernasocchi
> http://opengis.ch
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131011/8b9ca5d6/attachment.html>
