[Qgis-developer] test new android package
Marco Bernasocchi marco at bernawebdesign.ch
Fri Oct 11 01:45:09 PDT 2013
On 10/11/2013 10:42 AM, Roel Vanhout wrote:
> Tried on a Nexus 10 tablet, install worked OK. Only 'issue' is cosmetic;
> after the message that I need to install the 'necessitas' runtime, I'm
> redirected to the play store. When I return from that, I get the message
> (in qgis) 'necessitas not found' and I need to restart to resume the in-app
> installation procedure to continue.
mmm it shouldn't...
> Apart from that, is this meant to be more than a proof of concept /
> pre-alpha? Does it make sense for me to report bugs yet?
yes go ahead, this is ment to become the main way of installing
releases. Nightly builds will keep on using the old installer
ciao
> cheers,
> roel
> On Thu, Oct 10, 2013 at 6:55 PM, Marco Bernasocchi
> <marco at bernawebdesign.ch>wrote:
>> Hi all, I've been working on creating an android packae that is smaller
>> than 50mb to fit the playstore.
>> the pakage now includes only a small subset of the needed libs, all other
>> libs are downloaded on the first run by ministro.
>> all in all you will be downloding about 30mb for the apk plus 200mb
>> dependencies plus 40mb qt, so do it on a wifi, i know it got bigger (used
>> to be 150mb apk), but the adventage is that now qgis is small enough for
>> the market (thus update notification will be available) and for each update
>> you will have to rownload only what actually changed.
>> To achieve this, I created a reporitory at http://android.qgis.org/**
>> repository/ <http://android.qgis.org/repository/> that can actually be
>> used by any android qt app that needs any of the available libs.
>> so please, help me test this package and just report if the installation
>> worked and you could start QGIS.
>> thanks a lot Marco
>> https://db.tt/sBa0e2Pu
>> Marco Bernasocchi
>> http://opengis.ch
>> ______________________________**_________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
Marco Bernasocchi
http://opengis.ch
