[Qgis-developer] test new android package
Etienne Tourigny etourigny.dev at gmail.com
Fri Oct 11 11:55:16 PDT 2013
Installed on my Nexus 7 without any issues. However, cannot install any
python plugins dues to lack of python.
Cheers
Etienne
On Fri, Oct 11, 2013 at 5:42 AM, Roel Vanhout <roel.vanhout at gmail.com>wrote:
> Tried on a Nexus 10 tablet, install worked OK. Only 'issue' is cosmetic;
> after the message that I need to install the 'necessitas' runtime, I'm
> redirected to the play store. When I return from that, I get the message
> (in qgis) 'necessitas not found' and I need to restart to resume the in-app
> installation procedure to continue.
> Apart from that, is this meant to be more than a proof of concept /
> pre-alpha? Does it make sense for me to report bugs yet?
> cheers,
> roel
> On Thu, Oct 10, 2013 at 6:55 PM, Marco Bernasocchi <
> marco at bernawebdesign.ch> wrote:
>> Hi all, I've been working on creating an android packae that is smaller
>> than 50mb to fit the playstore.
>> the pakage now includes only a small subset of the needed libs, all other
>> libs are downloaded on the first run by ministro.
>> all in all you will be downloding about 30mb for the apk plus 200mb
>> dependencies plus 40mb qt, so do it on a wifi, i know it got bigger (used
>> to be 150mb apk), but the adventage is that now qgis is small enough for
>> the market (thus update notification will be available) and for each update
>> you will have to rownload only what actually changed.
>> To achieve this, I created a reporitory at http://android.qgis.org/**
>> repository/ <http://android.qgis.org/repository/> that can actually be
>> used by any android qt app that needs any of the available libs.
>> so please, help me test this package and just report if the installation
>> worked and you could start QGIS.
>> thanks a lot Marco
>> https://db.tt/sBa0e2Pu
>> Marco Bernasocchi
>> http://opengis.ch
>> ______________________________**_________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131011/e6f46b93/attachment.html>
