[Qgis-developer] Reliable way to determine a groupIndex in the legend tree
Fred Lehodey lehodey at gmail.com
Fri Oct 11 02:51:18 PDT 2013
just a thought, what about different "Group Styles/behavior" ?
- "default classic Layer Group"
- RadioButton exclusive group
- etc...
Fred.
On Fri, Oct 11, 2013 at 10:35 AM, Bernhard Ströbl
<bernhard.stroebl at jena.de>wrote:
> Am 11.10.2013 11:22, schrieb Sandro Santilli:
>  On Fri, Oct 11, 2013 at 09:13:03AM +0000, Duarte Carreira wrote:
>>> The group checkbox, imho, should *not always* switch children on/off.
>>> You should have a modifier to get this as a secondary behavior, like
>>> pressing the ctrl key when (un)checking the group checkbox. The primary
>>> behavior of the group switch should be to make the children invisible or
>>> visible, regardless of the children's visibility being on or off.
>>> In the primary behavior when the parent is turned OFF, the children are
>>> not drawn but retain their checked or uncheck status.
>>> If you use the secondary behavior then unchecking the parent will
>>> uncheck the children. Same would apply when checking the parent on.
>> Agreed, sounds like a sensible behavior to me.
> The problem I see is that we have layers visible in the canvas that are
> unchecked, because their group is checked. Maybe an unchecked layer should
> show a partly checked state in that case.
>> --strk;
>>  De: aperi2007 [mailto:aperi2007 at gmail.com]
>>> Enviada: quinta-feira, 10 de Outubro de 2013 12:59
>>> Para: qgis-developer at lists.osgeo.org
>>> Assunto: Re: [Qgis-developer] Reliable way to determine a groupIndex in
>>> the legend tree
>>> I guess instead that much better should be a group checkbox that
>>> enable/disable the under childs layer.
>>> This allow OFF the actual configuration or ON that same configuration.
>>> Actually the group checkbox when checked put ON all the layer.
>>> This often is mean too much information .
>>> Instead the mutual exclusive need to choose only one.
>>> And in that case disable and ri-enable will reput the same original
>>> clayer.
>>> Andrea.
>>> On 10/10/2013 10:08, Vincent Schut wrote:
>>> On 10/09/2013 11:41 PM, Nyall Dawson wrote:
>>> Personally, I am also interested in enhancing group options in the layer
>>> tree. Groups are not just stupid containers with only toggling of
>>> visibility. They could also have a group opacity and blending and group
>>> metadata. Later on we may also have clipping and masking on groups. So
>>> we really should have an extensible mechanism for groups as new group
>>> features appear.
>>> One thing I'd love to see is the ability to make the layers in a group
>>> "mutually exclusive". (ie, imagine radio buttons instead of checkboxes for
>>> controlling the visibility of layers within that group). I find I'm often
>>> going through a process of switching one layer on, then switching a bunch
>>> of other layers off for comparison purposes. A mutually exclusive layer
>>> group which automatically switched the other child layers off when I select
>>> a layer would make this process much nicer!
>>> +1 for this feature from a frequent user!
>>> Best,
>>> Vincent.
>>> Nyall
>>> ______________________________**_________________
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org**<mailto:Qgis-developer at lists.**osgeo.org<Qgis-developer at lists.osgeo.org>
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> __________ Information from ESET Mail Security, version of virus signature
> database 8904 (20131011) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131011/3d5ee8f2/attachment.html>
