[Qgis-developer] Gdal Tools: extract projection
Paolo Cavallini cavallini at faunalia.it
Fri Oct 18 23:52:35 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 17/10/2013 11:09, Alexander Bruy ha scritto:
> 2013/10/17 Paolo Cavallini <cavallini at faunalia.it>:
>> * no feedback is given upon completion ("World file written")
> Agreed, feedback about process completion will be good.
http://hub.qgis.org/issues/8916
>> * name is misleading (it is extracting a world file, not a projection)
> Hmm, it also extract projection into .prj file (optionally). Maybe both
> files (wld and prj) should be created by default?
>> * the prj is (optionally) created according to the project settings, so it is empty
>> for layers not loaded; the user should be warned, and the prj not created in this case.
> Hmm, works for me. Maybe your layers don't contain projection information?
unclear to me how to check this: the raster appears on the right place, however.
> BTW, I think it is better to improve this tool inside Processing as in future
> IMO it should replace GDALTools.
agreed - however, I think having the (editable) plain gdal command line at the bottom
is a major advantage of gdal tools for power users.
all the best.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlJiLDMACgkQ/NedwLUzIr5twwCgoIMpvm1O6a+DjwIuqOWRy85p
SicAn0GzE0kd6fH8OMU/t08ehaHHRtto
=leOp
-----END PGP SIGNATURE-----
