[Qgis-developer] vector rendering improvement patch
Andreas Neumann a.neumann at carto.net
Tue Oct 22 05:03:53 PDT 2013
Thank you for your work!
Yes - I think it should be configurable. It should also automatically be
turned off if a layer is in edit mode.
Just my opinion,
Andreas
Am 22.10.2013 14:01, schrieb A Huarte:
> Hello Vincent!
> For now, it is not configurable, automatically applies to all vector layer to be painted.
> I think that the userneed not configure this, of course, if dev-community suggests, will be as you say! :-)
>> Is it configurable in the interface for each layer independantly ? >It should probably be, as according to the style applied to the geometries, >the simplification could be something we want for some layers and not for >others. >A checkbox in the layer properties dialog could be interesting. >Then we would have to decide if we want it activated by default or not for >dataproviders supporting it. We could have a global option for that default >too. >Vincent
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
