[Qgis-developer] vector rendering improvement patch
Vincent Picavet vincent.ml at oslandia.com
Tue Oct 22 05:57:11 PDT 2013
Hello,
Le mardi 22 octobre 2013 14:03:53, Andreas Neumann a écrit :
> Hi,
> Thank you for your work!
> Yes - I think it should be configurable.
A use case is for example when a "line of symbol" symbology is used, with a
symbol on each vertex. Simplifying the geometry, even when it is not
supposed to be visible, could have undesired consequences on display.
> It should also automatically be
> turned off if a layer is in edit mode.
+1
Vincent
> Just my opinion,
> Andreas
> Am 22.10.2013 14:01, schrieb A Huarte:
> > Hello Vincent!
> > For now, it is not configurable, automatically applies to all vector
> > layer to be painted.
> > I think that the userneed not configure this, of course, if dev-community
> > suggests, will be as you say! :-)
> >> Is it configurable in the interface for each layer independantly ? >It
> >> should probably be, as according to the style applied to the
> >> geometries, >the simplification could be something we want for some
> >> layers and not for >others. >A checkbox in the layer properties dialog
> >> could be interesting. >Then we would have to decide if we want it
> >> activated by default or not for >dataproviders supporting it. We could
> >> have a global option for that default >too. >Vincent
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
