[Qgis-developer] vector rendering improvement patch
A Huarte
ahuarte47 at yahoo.es
Tue Oct 22 23:09:31 PDT 2013
Ok Andreas, I'm going to make it configurable, will present a new option in the main properties form of the layer
About of simplification in "editmode". I think is not necessary disable it, the simplification runs only on the method of painting "QgsVectorLayer::draw", not when you retrieve a geometry to treat your information.
Alvaro
>________________________________
> De: Andreas Neumann <a.neumann at carto.net>
>Para: qgis-developer at lists.osgeo.org
>Enviado: Martes 22 de octubre de 2013 14:03
>Asunto: Re: [Qgis-developer] vector rendering improvement patch
>Hi,
>Thank you for your work!
>Yes - I think it should be configurable. It should also automatically be
>turned off if a layer is in edit mode.
>Just my opinion,
>Andreas
>Am 22.10.2013 14:01, schrieb A Huarte:
>> Hello Vincent!
>> For now, it is not configurable, automatically applies to all vector layer to be painted.
>> I think that the userneed not configure this, of course, if dev-community suggests, will be as you say! :-)
>>> Is it configurable in the interface for each layer independantly ? >It should probably be, as according to the style applied to the geometries, >the simplification could be something we want for some layers and not for >others. >A checkbox in the layer properties dialog could be interesting. >Then we would have to decide if we want it activated by default or not for >dataproviders supporting it. We could have a global option for that default >too. >Vincent
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131023/f4f8421b/attachment.html>
