[Qgis-developer] vector rendering improvement patch
    G. Allegri
    giohappy at gmail.com
    Tue Oct 22 23:46:50 PDT 2013
> Ok Andreas, I'm going to make it configurable, will present a new option
in the main properties form of the layer
I suppose he meant to do not draw simplidied geometries during editing
because it would obviously lead to produce unconsistent edits.
giovanni
> About of simplification in "editmode". I think is not necessary disable
it, the simplification runs only on the method of painting
"QgsVectorLayer::draw", not when you retrieve a geometry to treat your
information.
> Alvaro
>> ________________________________
>> De: Andreas Neumann <a.neumann at carto.net>
>> Para: qgis-developer at lists.osgeo.org
>> Enviado: Martes 22 de octubre de 2013 14:03
>> Asunto: Re: [Qgis-developer] vector rendering improvement patch
>> Hi,
>> Thank you for your work!
>> Yes - I think it should be configurable. It should also automatically be
>> turned off if a layer is in edit mode.
>> Just my opinion,
>> Andreas
>> Am 22.10.2013 14:01, schrieb A Huarte:
>> > Hello Vincent!
>> > For now, it is not configurable, automatically applies to all vector
layer to be painted.
>> > I think that the userneed not configure this, of course, if
dev-community suggests, will be as you say! :-)
>> >> Is it configurable in the interface for each layer independantly ?
>It should probably be, as according to the style applied to the
geometries, >the simplification could be something we want for some layers
and not for >others. >A checkbox in the layer properties dialog could be
interesting. >Then we would have to decide if we want it activated by
default or not for >dataproviders supporting it. We could have a global
option for that default >too. >Vincent
>> >> _______________________________________________
>> >> Qgis-developer mailing list
>> >> Qgis-developer at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131023/a12f1cbb/attachment.html>
