[Qgis-developer] Excel export
Victor Gonzalez victor.gonzalez at geomati.co
Tue Oct 22 23:21:28 PDT 2013
Thank you, Richard. If you want I can work with you to upgrade the plugin
to 2.0. I have a current project now in which this functionality is needed,
so I can spend some time in this. What do you think?
Regards,
Víctor.
2013/10/22 Richard Duivenvoorde <rdmailings at duif.net>
> On 22-10-13 08:30, Victor Gonzalez wrote:
> > Hi all,
> > I need to export some attribute tables from QGIS in .xls format. As far
> > as I know, the XYTools plugin [1] does what I want, but it does not work
> > with QGIS 2.0 yet, right? I can update it and contribute the changes,
> > but I would like to know if it has been already planned or maybe the
> > plugin is unmaintained and there's a better solution that I can use. Any
> > thoughts?
> > Thanks in advance,
> > Víctor.
> > [1] http://plugins.qgis.org/plugins/xytools
> Hi Victor,
> I'm just too busy with other things.
> And I was/am in the middle of some bigger change: writing and reading
> all geometries as wkt columns (instead of only x/y). The core is
> working, I just have to do the gui stuff to make it work...
> But maybe I should postpone that and just do the little fixes needed to
> make the old version run in 2.0?
> Please give me some time....
> Richard
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131023/668da943/attachment.html>
