[Qgis-developer] Qgis : synchronized view for photo-interpretation?
Gino Pirelli
luipir at gmail.com
Tue Oct 22 23:47:30 PDT 2013
was a bug of mine introduces during porting to Api2.0... the original code
used toDouble...
I'm preparing a new version... thank you for the report
Luigi Pirelli (luigi.pirelli at faunalia.it)
On 23 October 2013 08:11, Zirneklitis <eko at lanet.lv> wrote:
> Hi,
> There is a problem with a comma as the decimal separator.
> A new bug has been reported:
> http://hub.qgis.org/issues/**8934 <http://hub.qgis.org/issues/8934>
> Best regards,
> Karlis
> Gino Pirelli wrote:
>> Hi, I'm maintaining this plugin
>> (Int)... so probabily in your settings zoom_factor is set as string
>> value... e.g "2" instead of 2
>> try to check in your Qgis setting
>> if this is not the case, please create an issue here:
>> http://hub.qgis.org/projects/**dockablemirrormap/issues<http://hub.qgis.org/projects/dockablemirrormap/issues>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131023/501196d6/attachment-0001.html>
