[Qgis-developer] Qgis : synchronized view for photo-interpretation?
Gino Pirelli
luipir at gmail.com
Wed Oct 23 00:13:55 PDT 2013
ok... prepared 0.2.5 version, thank you again
Luigi Pirelli (luigi.pirelli at faunalia.it)
On 23 October 2013 08:47, Gino Pirelli <luipir at gmail.com> wrote:
> was a bug of mine introduces during porting to Api2.0... the original code
> used toDouble...
> I'm preparing a new version... thank you for the report
> On 23 October 2013 08:11, Zirneklitis <eko at lanet.lv> wrote:
>> Hi,
>> There is a problem with a comma as the decimal separator.
>> A new bug has been reported:
>> http://hub.qgis.org/issues/**8934 <http://hub.qgis.org/issues/8934>
>> Best regards,
>> Karlis
>> Gino Pirelli wrote:
>>> Hi, I'm maintaining this plugin
>>> (Int)... so probabily in your settings zoom_factor is set as string
>>> value... e.g "2" instead of 2
>>> try to check in your Qgis setting
>>> if this is not the case, please create an issue here:
>>> http://hub.qgis.org/projects/**dockablemirrormap/issues<http://hub.qgis.org/projects/dockablemirrormap/issues>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131023/131236bc/attachment.html>
