[Qgis-developer] how to create project on hub.qis.org?
Alex Mandel tech_dev at wildintellect.com
Mon Oct 28 23:31:52 PDT 2013
Well, that statement isn't wrong. We do like for people to create plugin
repos on hub.qgis.org because it helps to make all the plugins more
discoverable and easily adoptable by other member of the qgis community.
It also means there's a single site for filing bugs for QGIS and Plugins
to QGIS.
However the process to create a new repo requires human interaction, you
have to communicate with us and then we say ok and grant you permissions
to upload plugins (the bar is really low). This is similar to how all
things to plugins.qgis.org are not automatically approved the 1st time
either. It's just spam prevention that a login doesn't auto grant
permissions.
The github thing, is just that it happens to be common for people to
already have and want to use github. The downside is we can't track bugs
all in once place. So we suggest if you use github that you use hub.qgis
for bug tracking. Note you could also use bitbucket, gitlab,
sourceforge, or whatever other hosting for your source you want.
Thanks,
Alex
On 10/28/2013 10:05 PM, Mikhail Tchernychev wrote:
> I got it now. The source of confusion was because plugin site says:
>> Please consider creating a project on hub.qgis.org <http://hub.qgis.org>
> It would be better if it would just say github.org
> Thank you
> Mikhail
> On 10/28/2013 08:27 PM, Nathan Woodrow wrote:
>> Hey Mikhail,
>> hub.qgis.org <http://hub.qgis.org> is just our own source code host
>> and tracking setup.  You are free to create a github repo and store
>> everything over there.  That is what a lot of people do.
>> - Nathan
>> On Tue, Oct 29, 2013 at 1:23 PM, Mikhail Tchernychev
>> <mikhailtchernychev at gmail.com <mailto:mikhailtchernychev at gmail.com>>
>> wrote:
>>     On 10/28/2013 06:50 PM, Alex Mandel wrote:
>>         On 10/28/2013 05:06 PM, Mikhail Tchernychev wrote:
>>             Hi,
>>             My plugin page says:
>>                 <http://hub.qgis.org> and filling the missing metadata.
>>             However I cannot find a way how to create new project
>>             there... I do have
>>             osgeo id
>>             and I can login in the right top corner of the screen but
>>             I don't see
>>             any way to create
>>             a new project... I would prefer to keep plugin sources on
>>             hub.qgis.org <http://hub.qgis.org>.
>>             Thank you!
>>             Mikhail
>>         I think someone has to grant your user permissions to create a
>>         subproject. Can you reply with your osgeo id.
>>         Thanks,
>>         Alex
>>         OSGeo Systems Administration Committee
>>     I was under impression that creating github repository is what
>>     almost any plugin
>>     developer does.  Perhaps I was wrong.
>>     Well, I won't bother anyone about this...
>>     Best Regards
>>     Mikhail
>>     _______________________________________________
>>     Qgis-developer mailing list
>>     Qgis-developer at lists.osgeo.org
>> <mailto:Qgis-developer at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
